Re: Home Electrical Question
Nope, no special challenges at all, DJ.
Just make sure the dimmer you get is a 3 way dimmer. Be careful, most 3 way dimmers can only be dimmed from one of the two locations, and the other location remains a standard switch. There are some (few) products that allow you to dim from both locations, but you would need to replace both switches then.
Make sure you do not exceed the maximum wattage of the dimmer. Most are 600 watts, but larger capacity ones are available. Also, this light you are dimming is an incandescant, right? Fluorescent adds a whole new twist.
Do you have toggle type or Decora (paddle or rocker) type switches? I highly recommend Lutron products, available at an electrical distributor, or most Home Depots.
