solar7647
- Joined
- Apr 23, 2009
- 1,218
So i tried wakeskating this year and loved it, but didnt have the cash to buy a new one. I did a little reserch and found they are pretty easy to make so this is what i came up with.
I used 5mm thick ply and laminated 4 layers together putting a layer of fiberglass cloth between each layer to help the board keep its shape.
I achieved a solid 2inch continuous rocker,it just so happened that my cradles i use to put the boat on when i need to work on it had the perfect shape to give me what i wanted. So i just set the boards across it applied the resin and put about 100lbs on it to keep the shape until the resin dried.
I then cut the shape i wonted out of the blank i made, its 40inches long, 15inches at the center and 12inches at the tip.
sanded out my shape and the edges
sealed the deck with resin to prevent water damage to the seems left after sanding
I then used a mechanics pad that i used when i worked on my car and laminated it to the deck, then cut off the flashing to get a nice comfortable deck
