Boat exhaust
Hello everyone,
This is my first post here so I apologize if my terminology isn?t correct or I?m posting in the wrong place
So, I have a 96 Wellcraft 2150SS 21? with a 5.7 mercruiser engine and an alpha one gen II drive. It?s my first boat so I?m trying to learn as much as I can about it. I got this boat about 6 months ago and it was running perfectly except it was leaking water into the bilge area so I thought I should change the bellows but that didn?t stop the leak. So, in the last 2 days I took out the drive and the engine and I plan to drop it in water today to see were the leak is. I checked the engine and the transom seals and found no leaks.
Now, since I had my engine out, I started thinking of adding a new exhaust to it. What I plan to do is this:
- Remove the Y pip and close off where it connects to the transom.
- Fabricate a new 4 inch stainless steel pip that goes to the side of the boat. Pointing slightly down and backwards and above water level.
- And obviously, cut through both sides of the boat.
Question is, would my plan cause any problems? For example closing off where the Y pip connects to the transom? I plan to close it off with a stainless steel piece that is shaped and cut exactly like the Y pip bottom.
Is there any electrical work done?
Adding an external exhaust, does it harm the engine?
Thank you very much in advance.
cheers
Hello everyone,
cheers
