janthony1001
Thread starter- Joined
- Dec 14, 2003
- 9
I have a 99' 130 on a 25 ft sea cat and I just got the craked block repaired about 3 months ago on the port engine and that engine only turns about 5000 rpms and the other engine turns about 5500 rpm but now the engine has a spark problem now. I changed the plugs and the bottom cylinder plug was fowled pretty bad. I changed the plug and it didnt change the the way it ran. I pulled the plug cap off and it still did not change the way it ran. Then I wiggled the plug wire and it then ran right. all this work is with ears on the foot. The next day I went and ran it. it still didnt run right it even ran worse until I played with the plug wire. common sense says it is the plug wire but I dont know if I can change just the wire or if I need to change the coil and plugs for number 3 and 4 clyinder help thanks
