Honda 25 HP.
Steve watts
Because the spec's are the same is there a procedure to increase the horse power of a 25 to 30?
Sea Rider
Welcome to Iboats,
Why would you like to increase the HP ? If both OB's are same CC, the restrictions could be : timing advance/carb synch, carb model, reed valve plate, valves, props, etc. Upgrades costs will depend entirely if it's a 2/4 strokes carbed or fuel inyected model. Check both 25-30 HP spare parts manual and see which parts differs. The upgrade could turn into a costly one depending on how many parts need to be bought and swapped..
Happy Boating
Alumarine
Also need more info to answer your question.
Like model numbers etc.
Honda has made a number of 25 and 30 hp motors.
As SR says, check parts manuals. I'd see if the cams were different.
