I have a 1994 BF 45 Honda. While running the boat, I noticed a weak pee stream at higher RPMs. After a 5 minute run the alarm went off. At under 1500 RPMs there was a pee stream and the alarm would not sound. I idled back to the dock.
I replaced the water pump (impeller and entire pump housing). While the lower unit was off I ran air through the motor and could feel it coming out of lower, so I assume it is not clogged. I also checked the tell tale and it was clear. I also checked the water screen and it was not clogged. The impeller was in ok shape, but the pump liner was a little banged up.
After replacing pump and lower unit, I put it on the muffs and it was not peeing at all. I checked the thermostat and it seems dry. ??? The alarm did not go off. I plan on replacing the thermostat, but does anyone have any other suggestions.
Thanks.
Thanks.
