Re: Honda 50hp No Acceleration
I had a similar problem last year after a service. It turned out that one of the clamps on the fuel line was sucking a bit of air.
Easy tests to see if its the problem or not is to:
A. pump up your fuel and see if the fuel bulb is hard or soft at the end of it. If the bulb never gets fully hard, it could be sucking air from somewhere.
B. operate the engine at WOT for a couple of minutes, back off the accellerator to about 1/2 throttle for about 2 minutes then suddenly go to WOT again. If it hesitates or cuts out completely, it could be sucking air.
In my case I found a clamp that whilst tight, had been overtightened and wasnt making a good seal. I took the clamp off, cut about 1 inch off the hose, put a new clamp on, pushed it back onto the fitting and tightened it and the problem went away.
Hope it helps
