sandiegofisher
Thread starter- Joined
- Sep 8, 2002
- 11
And the saga coninues... About 86 model BF-75 4-stroke Serial # above 7100001<br /><br />After replacing the fuel pump, oil pump, head gasket and after cleaning all the carbon and salt water buildup in the crankcase & valves, readjusting float, timing and spartk plug gap. I finally get this thing running nicely... for about 20 minutes.<br /><br />It developed a loud knock and then threw a rod bolt right through the crankcase cover! Upon inspection (through the gaping hole left) I discovered one of the connecting rod bolts had worked loose. Apparently whoever worked on this engine before me did not put the tab-lock washers in.<br /><br />No.2 cylinder still intact but lacks this washer too. Nothing else appears to be damaged just crankshaft cover and the bolt that got shot out. <br /><br />I can get a used replacement cover but was wondering if the pieces could be welded back on? And would also like to know what else I should check while I've got it torn down.<br /><br />Are these missing Tab-Lock Washers the cause or is it most likely something else? The engine turns by hand and is not siezed. A major set back in getting this old Honda running.<br /><br />Thanks again for all the help. You've gotten me this far and I'm not ready to give up on it yet.
