honda oil check
90sunbird
on a honda 1200 acuatracks turbo 2004 do you check the motor oil when the ski is running or off
Armada1950
Re: honda oil check
I've got an 03 F-12X. Lift the seats off and look at the forward part of the engine. There is a black screw-on cap that is the dipstick. If the engine has been run recently, the oil level should show on the dipstick. If you don't have any oil on it, then you have to check the rear port side of the engine below the black seat support. There is a "filler tube" there for the oil. If the engine hasn't been run in awhile, the oil will be down low in the sump. Use the dip stick from the top to check the level in the lower tube. Hope this helps!
