Hone Cylinder walls?
captkid
should I hone the walls before I install new rings? There is some surface rust. I have a Merc 470 190hp... <br /><br /> :confused:
Spidybot
Re: Hone Cylinder walls?
..some rust...? <br />You should make sure the walls are as good & clean as at all possible.
f_inscreenname
some rust!!! If there is any rust your new rings will last about 10 seconds.
captkid
just wanted to be sure <br /><br />THANKSSSSS :) :)
jlshields
Rust in a Merc 470? Isn't that an aluminum block? Maybe with sleeves? If it is a sleeve engine go ahead and hone. If all aluminum you want to talk to a shop who does this. You have to be VERY careful honing aluminum. Either way you want to do something about the rust.
jlshields,<br />They Have to have Sleeves........<br /><br />An Aluminum Cylinder would last Minutes.......
jlshields
Sorry Bondo. Lots of engines have aluminum blocks with no sleeves. Have for years. Especially air cooled small engines. Ever been inside a Brigg & Stratton? Tecumseh? Clinton? And they run a lot hotter than water cooled marine engines. Talk to a shop guy. They usually don't hone alum clyinders. They have a glaze in them that honing destroys.
LubeDude
If its got rust, IT AINT ALUMINUM, Also if you have to ask if you need to hone the cylinders before re-ringing, What are you doing rebuilding an engine anyway. Dont get me wrong, Im all for someone doing it yourself, but there are a LOT of things to rebuilding an engine other than just putting a bunch of new parts together that Im thinking you dont have a clue to. :eek:
Walt T
Right on Lubeadude, I didnt want to say anything.
LubeDude
Well, I never did have much tact, I just hate to see someone waste a bunch of money and have the thing self destruct when he tries to fire it up. Probably never heard the term, "Pre Priming". I honestly hope Im wrong.
captkid
Right on Lubeadude, I didnt want to say anything. <br />
and let me guess you both were born with oil running through your blood? righhhtttt... I mean I respect your knowledge you have NOW, but you had to start from the beginning as I am doing!! (if I am wrong please stop me)<br /><br />how will I ever learn if I dont try?<br /><br />DieselWalt, u really shoulda spoke up sooner!! I never did like a follower...<br /><br />anyways... thanks to all that have helped me, appenertly you have to to be a "certified mechanic" to post on this board. anyone know where I can find a board for people new to mechanics??
LubeDude
CaptKid:<br /><br />We may have been a little hard on ya, but what we said still holds true. We admire you for wanting to do it yourself. The best thing you could do would be to get a manual about the engine in question. Most have a section on re-building. Read it, and re-read it, and read it again. If you are going to continue with this project, we will be here to give you all the support you need. Buy a cheap engine stand, you do not want to do this on the floor. I remember the first 283 Chevy I rebuilt, I followed the Hot Rod Magazine on how to rebuild your first engine. I did everything right, except to check the end gap on the rings, Turned out I had the wrong ones, The engine was boared .60 over and I had stock. I had to tear it apart and re-ring it with the right ones. It did run however, but boy did it have blow by when I pulled a hill. <br /><br />You are right, you have to start somewhere.
captkid
LubeDude<br /><br />I have a Merc Service Manual, and I have the engine on a stand, and I have a brother that is a gearhead. So I have most of my bases covered.<br /><br />I dont like doing things twice so thats why I ask questions. Sometimes stupid ones. but if it prevents me from having to tear down the engine to put the proper rings in ;) , then I see the questions as being valid. <br /><br />I mean any fool can read a manual, but I feel peoples experiences are much better at telling the truth.
WOW,<br />LubeDude, Thanks for Defending My Honor, with the Rusty Aluminum Cylinders............... ;) <br /><br />A Little Too Much Caffine today ????<br />Don't be Pickin' on My little Maineiac Buddy.......<br />I've been Looking Up the Answers to All his Dumb Questions for a week now...... <br />I Know More about the 470s than I Ever Wanted Too..... Now....<br />He seems to Know the Answer, He just needs Confirmation.......... ;) <br /><br />I Still Think He Shoulda brought the Whole thing to a MachineShop......<br />But,........ It's His Money............. :p <br /><br />I'd have Already Dropped a Small Block Chevy in there by Now.......... :D
