JSGOLD
Thread starter- Joined
- Sep 22, 2009
- 609
I am adding a 1961 Evinrude 5.5 as a kicker motor to my 76 Starcraft.This motor came with a control box, which previous owner used on an older boat he had. The control box is a Scott Atwater, which is pretty old, but works fine. The motor has the lock down clips already and the throttle cable hooks right up. However on the shifter the end clip is missing from the cable, and the shifter, while it also has the lock down clips, has no way to connect to it. I would assume at one time the fellow had a bracket of some sort on there, but no more. Would it work if I added an "L" bracket, drilled a hole in it, and added two nuts to hold the cable onto it? Or, is there a better solution. I can't locate any of the clips, and I would assume based on the age of this control box, it would be hard to find. I am adding a kicker because 70% of the time I will be in lakes with 10hp limits, and it would be easier to use control box. I am getting a 3gal tank for the motor, as I see from previous questions it is a 24-1 mix. If I can just get the shifter hooked up this would be ideal.
