Boomyal
Thread starter- Joined
- Aug 16, 2003
- 12,072
2003 Mitsubishi Lancer. The horn does not work. The car had been in a front left collision that resulted in damage and replacement of the front hood lock panel where the horns are located.<br /><br />I do not have a wiring diagram but I have this recollection that horns are switched off the ground. Is this correct? I do have constant power (key on or off) to the fuse for the horn and suspect that there might be a break in the wire to the horn due to the collision. <br /><br />Any help to diagnose would be appreciated.<br /><br />There are two horns bolted to the center hood lock panel strut, each with one with a single wire coming out of a harness to the connector on the horn.<br /><br />Once the power leaves the fuse box where does it go. I think the contact in the horn button is on the negative side.
