americanmcss
Thread starter- Joined
- Jul 18, 2012
- 58
Hey everyone. Its been a while since I've been in the forum, but this is usually the best place to learn from those who have "been there, done that". A series of buying and selling and trading in boats and motors landed me with a cheap, old, evinrude 25hp tiller, early '70s vintage. It was bought from a retired Evinrude/Johnson mechanic who rounded up old motors and freshened them up with parts he bought from defunct dealers and swap meets. I think I paid 250 for it. It ended up being too powerful and heavy for the transom rating of the fishing boat we acquired so I put it up for sale or trade for a smaller motor. I ended up with a well used, but running honda BF100 4 stroke with CDI. A local guy used it on is fishing and crabbing boat, so it had seen salt water. It was missing the proper kill switch and the throttle friction nut, but it ran very well in the barrel. It wound up in storage after that for a couple of years and I just pulled it out a couple of weeks ago. I had never actually run it on a boat so it wasn't until last weekend that I found out it has serious power issues. I went through and did what I could to clean up the electrical contacts and spark plugs and wires. Greased the moving joints, changed the gear oil and went ahead and put a new water pump impeller in there as well. In forward gear at WOT I could barely get the boat above 5.5 mph. For perspective, our Evinrude Deluxe 4hp short shaft will push the boat at 4.5mph at WOT. I could tell the engine struggled to reach maximum rpm, and I'm guessing we reached only 60-75% of maximum. It would run at WOT for about a minute before it would suddenly die. It would start again right after and run another minute and then die. We did what we could on the fly in the lake with no positive results. Got it back home to the barrel, where it appeared to be healed. I cleaned the fuel filter inside the pump and removed some debris, made some more carburetor adjustments, and adjusted the timing via the timing belt all with positive results. I replaced the kill switch with an aftermarket safety/lanyard style and found an OEM friction nut to install. All in all its a complete, running engine but I need some help.
Anyone with some insight here?
