Re: Horsepower help . . . or how do i get my butt out of the water?
There are heaps of variables in place here..<br /><br />1. the boat, fiberglass or Aluminiun? the former is way heaver then the later.. so it will need considerably more power to tow you.. <br />2. Weight overall, how loaded is your boat gonna be? fuel, people, fishing gear, that sort of stuff... the more weight, the less speed and takeoff.. <br /><br />Hull design.. some are fast, some are not.. depends how much water it displaces (or has to push out of the way) when its moving.. the more it moves, the more power required to do it.<br /><br />So as you see, its sortof hard to guess.. it would help if you had a boat model/type to base this on..<br /><br />rgds<br /><br />Frank<br /><br />(having said that, I've seen people sking behind a 60 hp on an aluminiun, and I suspect that my 100HP will pull me up on a 17 foot FB halfcabin.. which is very narrow, flat hull and shallow nose.. and I am 6 foot 4 as well, (247 pounds).
