thomasando
- Joined
- Jan 20, 2013
- 22
Got home from a good day out yesterday, had the muffs on and outboard flushing while I was sorting some gear near the boat. I didn't notice the hose had fallen off (the hose has a 'stopper' fitting on it so if it's on and not attached to anything it doesn't waste water) and heard the alarm. Shut the motor down as quickly as I could get round to that side of the boat (5 seconds tops).
I have a few queries about this alarm
- Does it sound BEFORE the motor overheats? Ie. does it sound when the operating temperature goes above normal, but before it's at dangerous levels?
- Is shutting it off and letting it cool the correct way to proceed? I didn't realise the hose had disconnected until after I'd shut it down and went to investigate. Should I have hooked the hose back up straight away and restarted it to get the temperature down?
After it did cool down I reconnected and ran it and the flush finished (under close supervision) without issues, seemed to be running fine. At idle, anyway.
