floater212
Thread starter- Joined
- Nov 27, 2013
- 147
I have a rinker captiva 212 2005 350 mpi. Here's a weird problem I had the sun deck cover fixed from a seam split when it was repaired the shop pulled the edges down it puffed out the sides so the fit is tight around the opening. So tight there is no or very little air going into engine compartment. Now it's real hot in there. Anybody have this problem? I have a side walk-in from swim platform the side which is also the engine compartment has a cubbie where I store docking lines. I'm putting in a 4" vent which I'll add vent hose to a blowers to force more air in. I think that will work out great. It will get more air with or without blowers on like an air scoop. I'll let you know in the spring.
