fireman57
Thread starter- Joined
- Aug 24, 2004
- 3,811
'83 evinrude 50hp. running fine out fishing the other night and just idling and casting. Engine just quits. Pull the cover and the flywheel is hot but the heads are fine. Pulled the lower unit and oil was milky. Checked new impeller and all seems fine there. Replaced a powerhead gasket the other week and missed a piece of old gasket on powerhead and had a small water leak that would run down the back side of the engine. Not sure what that would hurt so I have left it for now. When I replaced this I found that the exhaust tube had come loose and was hanging by one bolt. This was fixed immediately. When this exhaut tube was loose it would let water fly everywhere in there and I wonder if that is where my lower unit water is coming from. All I can assume at this point is that when the water got in the lower unit oil it did not lube right and the heat was transferred up the drive shaft to the flywheel. The engine stopped due to being hot but the heads were cool. There were no metal shavings in the lower unit. One other thing, my battery connection to my starter solenoid was almost off (due to my not tightening it when reassembling) could that have led to my stator heating up and that be my problem? Any ideas would be helpful.
