bitsnpieces
- Joined
- May 8, 2006
- 22
hello all,I have some concerns with the temp I'm getting from my J140TLCDC.I just installed a water pump kit,and new thermostats.The impeller that was installed was the pin drive type and was obviously not turning due to markings on the impeller and drive shaft.I replaced it with the wedge type along with all the parts in the kit.The motor got hot enough to melt the verntherms into their casings as well as melting the water fittings on the housings.All has been replaced and a compression test read 130 on all 4 cylinders.I ran the motor on the muffs and got a good stream from the pisser.The concern I have is the steam that was coming from the water flowing out of the exhaust.It only ran for a few minutes because it was idling too fast and I need to do a link and sink.I hope someone can shead some light on this for me.Sorry for the long post but I thought it might be necesary.<br />Thanks In Advance
