I have a 1985 Mercury 135hp black max V6 outboard motor. while running, the temperature increases directly proportional to the increase in rpm.<br />At around 2500 to 3000rpm it's at the 1/2 way mark on the temp gauge. at 4000-5000 rpm it's at 3/4 or a hair over. at idle its just under the 1/4 mark.<br />There is a strong stream of water out the pee hole at idle and also at high rpm. At high rpm, there is also water pushing out the exhaust (which has been normal for this motor).<br />I have been through all the "posts" on this site and have done most checks;<br />compression in all cylinders 125 psi, within a pound or 2. Checked the poppet valve, appears ok. the water pump was replaced 2 years ago,and the motor hasn't been run much. I looked at the impeller and it looks good. I put the thermostats in appx.180 deg water and they open.<br />I ran the motor on the hose & muffs
- with the stats out and water shoots out of the housing on both cylinder banks. I've also flushed the motor with a hose through the pick up tube with the poppet out and the stats out to purge any material that might be in the system. The motor has only been run in fresh water. Sould I replace the t-stats just in case? I am at a loss for what more to check. I have not had the overtemp warning buzzer go off, but the motor operates too hot for my liking. In the past it has always run no more than 1/4 notch on the temp gauge even at WOT.
