peterpagnott
- Joined
- Feb 15, 2004
- 26
I have a 2003 Merc saltwater 2 stroke. My tell tail stream is hot, to hot to hold your hand under. I have replaced both thermostats, the impeller and the poppet. Last night I took off the poppet to find blockage in the line and built up in the housing. I then checked all of the water lines up top and found no other clogs. When I started her back up the tell tale was still hot and was not cooling off. She is out of the water and I was only using muffs. Should I water test before more trouble shooting? Whats next for trouble shooting? As a side question, does the poppet casing have a weep hole?
