Silversound
- Joined
- Nov 17, 2010
- 23
1993 Mercury XRi 150
I changed the entire water pump a few days ago. At high RPM's above 3000k the pressure goes up to 10psi. At WOT is will go up to 16psi but if I try to go at a slower speed under 3000k the motor starts to heat all the way up to 180 degrees. If I keep a speed over 3500 rpm the temperature stays at 140-150 degrees. Any suggestions.
Thanks
Thanks
