Hot to check I/O motor mounts?
97formula1234
Got a 89 Maxum open bow. The floor was badly rotten with a hack job floor replacement over the old floor.
The one front engine mount looks like it has a crack in it but when i pried it open their was stiff glass under it, so i think it was just a bobble in the glass.
The bolts all seem to be tight (just checked with my hand)
Transom, i tapped on it and at the bottom of it it sounds pretty hollow :mad:
So i want to make sure the engine is holding in place so it doesnt put any strain on the transom.
proshadetree
Re: Hot to check I/O motor mounts?
Drill in to it if its wet or rotten youll need to pull and replace.If its dry plug with resin and cloth.
