Re: hour meter installation
The above is as good as anything - any point in the electrical system which is live when the ignition key is "on". Usually the engine is running in this state.<br /><br />However, if you want to be fanatic and actually have it measure the hours the engine is really running, that can be tricky and could involve anything from putting in an oil or water pressure gauge and using it to trigger a relay. Or you might find some point in the charging system that has voltage only when the engine is running (would have to be before the rectifier/regulator since you'll see the battery voltage beyond that point.
