Housing
Jrato14
Hello question, what would you consider the outdrive housing?
Jrato14
On the appraisal for my boat before I bought it it said they replaced the outdrive housing as a bolt broke off and took on the water
dubs283
Colloquial reference to the halves of a sterndrive unit is driveshaft housing (upper) and gearcase (lower)
Jrato14
This is what is says so I should assume upper?
Donald0039
I think you need more details on exactly what repairs were done. If a lot of water got into the outdrive it needs to be completely disassembled. All gears and bearings examined for rust or other damage and then the drive out back together with new seals.
I am assuming what was replaced was the transom housing. Which is what the outdrive is bolted to.
Seems odd that any one bolt breaking off would cause significant damage or allow water into the the engine area.
