ScottinAZ
Thread starter- Joined
- Jun 25, 2009
- 865
and onto the engine driven seawater pump. Loads easier to service than the "outboard" style of the Mercruiser.... two bolts, and two hose clamps and its off.....
Impeller is toast... not cracked, but has taken a pretty good "set" due to not moving really since 2017. Front seal is toast.. it leaked on initial movement of the crank when troubleshooting the cranking/starting issue (that precipitated this whole thread). At least its serviceable. A couple of screws through it, and its right out.... (and awaiting parts, again).
Ill be cleaning up the housing with some scotchbrite to get rid of the little bit of crusty corrosion present. Doesnt look like it ate into the housing too bad. At least its "fresh water"......
