How Bad is a Cracked Exhaust Manifold?
stb100
Would be very grateful for insight/experience with the following -- Found about a 2" crack in port-side exhaust manifold on '84 Wellcraft (200 elite 260HP merc.) Runs horizontal, cente, sort of low. Little bit of rust, water seepage. Evidently been there awhile
Few questions from stupid ?? dept.:
-- Worst case scenario?? How urgent is need to fix?
-- How big of a repair job is it? Time/effort/cost... (Other stuff that'll need fixed due to this)
-- Any recommendations on DIY vs shop
THANKS in advance
STB
tommays
Re: How Bad is a Cracked Exhaust Manifold?
Outside leaks are BAD but the problem is its hard to see the INSIDE leaks which are really BAD
Tommays
stb100
Thanks. BAD (outside) would become clear to me exactly how...? Something quick and catastrophic or something a little less dramatic... ; )
BAD (inside) means water and oil together, no?, which you're right is, uh, very BAD.
milkyway
Exhaust manifold is the exit passage of carbon monoxide and if there's a crack, it will spill into your engine compartment. How bad is that?
tommays
Outside leaks from cracks point to freeze dammage :(
which makes the inside a time bomb and the dripping water tends to cause a LOT of rust dammage to the sheetmetal parts and electric parts
Tommays
milkyway
And even worse if you have unburned fuel coming out of your exhaust and it's coming out of the crack.
bruceb58
Honorary Supreme Mariner
You aren't going to be getting exhaust out that crack because that is the water passge.
However, like a previous poster said, an outside crack means it could be likely that the inside passage could be cracked which is worse since you could damge your engine with water ingestion.
When you change your manifolds, you should change your risers. The dificulty of this job depends mainly on how easily accessible the manifolds are and the amount of corrosion on the manifold bolts. Mine come off easy because there is so much room. On a previous boat it was more difficult because the manifold was on studs and the manifols couldn't clear the studs before the boat got in the way...PITA!!
bjcsc
Actually it doesn't mean water in your oil. It means water can get to your exhaust valves, which then means either the valves temper and break (BAD) or the corresponding cylinders fill up with water, which does not compress. (VERY BAD, esp. if it occurs while running hard)
As said, if the manifolds and risers are easy to get to, they're pretty straightforward to replace. The bolts and holes should be cleaned with a die and tap before installing the new parts in order to get accurate torque readings.
milkyway
I suppose you still don't own the boat. You have not stated that you have actually seen anything coming out of the cracked manifold.
AlanR
if its outside it will leak into ur motor compartment. Mine leaks really bad and i just run the bilage pump every 2 hours and shes fine.
bruceb58
I hope he is kidding!
cobra 3.0
By the description of where it is, it's just a little water coming through on the belly of the manifold. ..probably from not draining the manifolds and freezing occuring.
I seriously doubt any of the gloom and doom based on the location of the crack. If you don't run in salt, take it off, grind out the crack, and JB Weld it...or get it welded.
You will certainly want to inspect all the passages on the engine and manifold when it's off. It should be quite evident if it's something more serious.
If you run in salt water or the boat had at one point, get new manifold(s). The're probably shot from corrosion anyway. Again, this will be evident once it's off.
stb100
THANKS for all the input and clarification.
The more I know, the more I know I oughta know.
Crack is low, not under, but near bottom of vert surface of manifold...don't know but could be due to freeze... : ( There is a very small amt of water seepage coming out w/ engine off. Haven't had chance to look w/ engine on. (for the record I own the beast, mw...Or it owns me)
STB
Haut Medoc
Pull it off & look for rust on the exhaust valves.....
If they are clean, replace the manifold & riser & go boating.......
Assuming that this is a raw water cooled system, you should replace the other side at this time as well ;).......JK
Oh, & make sure you learn the proper way to winterize/drain your system.....
MelLandry
If you're worried about this while you're running, are you really going to enjoy yourself on the boat? I got my whole set for my new engine (manifolds, risers, gaskets) for $400. If you're enjoying yourself, you'll burn more gas than that in a season, and it'll all be worth it. These are expendable parts that are intended to be replaced every-so-often.
stb100
Excellent point, Mel. ...someone wiser than me put it, 'enjoy yourself,
it's later than you think.'
Looking em up online this aft. Where'd you get your set? Curious about best online parts sources...
THANKS -- stb
MelLandry
I got mine from aftermarket marine.
www.amarket.com
It's not the most attactive website... but it works. Give them a call, tell them what you have, and they'll tell you what you need and how much.
I like them because they're local (one city over). Someone else may have a better source.
