How big a PITA is replacing the gear oil fitting on transom?
Status
Not open for further replies.
Dshow
Long story short, removing the bell housing to replace the bellows on my alpha 1 gen 2. Yes, I should have cut gear oil hose, but did not... Cut the tie wrap on the plastic right angle transom fitting and tried to get the hose off. Worked and worked, finally the hose barb snapped. It's off now... :) :( Are there any options other than replacing it?
Thanks-
Don S
Re: How big a PITA is replacing the gear oil fitting on transom?
No, that is a really sorry setup when they went to that cheap plastic from the brass ones. They can also be impossible to get to beacuse of boat design, another fun design error.
Dshow
Thanks Don. Looking at the picture, it looks like is has a E clip and a quick disconnect on the other side which is better than I thought... Is this the part I need, 22-861150T02?
Fun Times
The hardest part of the job is everything that needs to be done on the inside of the boat. Not much room down there for your hands.
Once you get the quick connect fitting off and the E-ring off on the inside of the boat, the gear lube fitting will pull out from the outside of the boat.
Here's what it should look like,
Google Image Result for http://i.ebayimg.com/t/NEW-OEM-MerCruiser-Alpha-Bravo-Gear-Oil-Lube-Fitting-KIT-22-861163-22-861150t02-/24/!Bvv6kYwEGk~$(KGrHqYOKjwEvotcV)VcBMF3Tlh)OQ~~_35.JPG
Item #1,
http://www.mercruiserparts.com/Show...=2686&bnbr=270&bdesc=OIL+RESERVOIR+COMPONENTS
There are three pictures in here to help give you an idea if needed in the link below,
Fitting Connection Photo by dln_2009 | Photobucket
Good luck.
Don S
Yeah, that should be the one you want. If you can see that E clip, you have it made.
Dshow
Thanks everyone... That will be tomorrow's job.
achris
More fish than mountain goat
After I heard about that silly little plastic fitting I looked at all the parts and part numbers and I believe the old style brass fitting can be retro fitted back in. From memory it does mean not having a QD fitting on the back of the transom, but there is another QD further up the line (towards the oil reservoir).
Chris................
Fun Times
Hum, I'm not so sure i would be comfortable with doing something like that since service bulletin 98-12 mentions the composite fitting assembly will not back fit into the Alpha and Bravo Transom assemblies that have the brass fitting, because of a machining change to the gimbal housing for the new fitting.
http://www.boatfix.com/merc/Bullet/98/98_12.pdf < now https://www.crowleymarine.com/sb/2/4679
Update Edit: Michigan Motorz.com appears to have now created its own version of the plastic gear lube fitting in Brass but at higher cost though...,https://michiganmotorz.com/mercruis...chid=30889&search_query=Gear+Oil+Lube+Fitting
achris
Thanks FT... Didn't see that SB...
Cheers.
Baylinerpete
I been trying for hours to get that e-clip on. bought long needle nose and the one with a bent tip. I still can't get it on.My hands are to big and you can't see the fitting...
achris
This thread is 8 years old. When you signed up to iboats,I assume you read through the forum rules and read the paragraph regrading posting to archive threads...
Please start a new thread of you have a question or comment.
Chris.
iboats mod team
Status
