Re: how big of bilge pump do i need?
At 10 feet, the wire gauge should be 14 (AWG) to get a minimimal voltage drop. The smaller the wire, the higher the voltage drop will be, and the pump will run slower.
Also note that marine wire is rated in the American Wire Gauge (AWG), which is 12% larger than the Society of Automotive Engineering (SAE) gauge. If you are buying wire at the auto supply, or Radio Shack, remember to go one size larger to keep within the specs for your pump. More important, although SAE wire meets minimum marine requirements, it does not meet requirements for bilge pump use because of the moisture and fuel/oil restance requirments of bilge pump wire.
BTW, before you buy a Rule pump, you should check out the Attwood line. Their S750 and S1100 both pump more than the Rule 750 and 1100 at 3.3 feet of head at the same voltage, and do it using less amps. The review I read rated the Attwood pumps performance the best, but knocked them down for not having tinned wire, they just had marine grade wire. That was a few years ago. Now all Attwood pumps (except for maybe the smallest manual pumps) come with tinned marine wire standard.
The amp rating is important for boats that are moored. Less amps used means the pump will run longer than a pump using more amps.
If you don't know where to buy marine wire, a number of members (myself included) have had great experiences buying from Greg at gregsmarinewiresupply.com Look at the 3 wire bilge pump wire. It makes switching a pump easy, and has an extra heavy jacket to protect from chafing, water and gas.
If you are adding a pump for the first time, you might find this project interesting:
http://shareaproject.com/pages/projectTut,p,512,00.html
Spend your money wisely.
