Re: How big should my kicker be?
Walleyehead, I was abreviating my remarks because we've gone over and over this issue before. It's not rocket science: it's marine science. Sorry I didn't make myself more clear. All Formulafisher did was ask the time and I'm now going to explain how a clock works.
<br /><br />The speed of boat @ displacement is based on the marine formula: boat length sq root X 1.3 = speed in knots X 1.2 = speed in mph. Doesn't matter if you're using 9.9 hp or 30 hp., a (say) 24' boat isn't going to go much faster than 8 mph. Period. WHILE IN DISPLACEMENT MODE. <br /><br />That's the formula. Of course, the formula doesn't take into consideration currents, wind, hull design or other factors. So while it might not take more than 5 hp to get my 24' Seaswirl at its maximum trolling speed, I still need more HP to control it better in those conditions mentioned above....mostly because, like most planing boats, it makes a lousy displacement boat.<br /><br />Lighter boats beat the displacement theory. Kayaks, well-designed canoes, some flat bottom boats and some catamarans go faster than they "should." Further, a jon boat, for example, is much easier to get on plane (or at least semi-plane/semi-displacement) than a deep V., thus the phenomena of jon boats planing @ 25 mph with 18 hp. <br /><br />Correspondingly, a well-designed heavier boat goes quite well with minimum horsepower. My 32' Grand Banks has 140 whole horsepower, and those retrofitted with 185 horsepower still aren't going to go faster than my 8-9 mph. The boat's gone quite well through 12-15' swells, 40-60 mph winds with that 140 hp and more horsepower would not have made any difference (the boat did better than I did...next time I trucked it from Portland to Seattle and back...I decided I'm not a Pacific Ocean kind of guy). The marinas are full of Kroegan, DeFever, Nordlund, etc. trawlers that go around the world with single diesels in what outboarders would consider ludicrously low horsepower because more would be just flat wasted horsepower.<br /><br />So how much of an engine should Formulafisher get? Oh, 9.9 to 20 should do it.
