Hi all.
Just picked up a Merc 850 XS, approx '76-78 as far as I can make out. The motor is running and pumps water but has no prop. The gearbox lever seems to shift ok. When lever is at one end the prop shaft will not turn in either direction. When centered there is a neutral, prop shaft turns both directions freely. Lever other end, prop shaft will not turn one way, but will turn in other direction and kind of clunks/ratchets when it turns.
Above test without motor running.
Does this sound normal? What checks can I do? Running test?
Hope to get a prop soon.
Any help much apreciated.
Dave
Dave
