Re: How can I clean the old varnish in my gas tank
I had a tank so fouled I had to drain it, and clean it out. Mixing and dissolving the goo into fresh fuel was out of the question, it was so bad. <br /><br />I drained it as best I could, then put a gallon of Lacquer thinner in it. Then sloshed it around, reached in with a rag on a steel rod and scrubbed the tough spots. <br /><br />Then caping the filler hole, and blowing air into the vent, pushed the mess out the outlet line.<br /><br />I Rinsed and repeated the flushing/scrubbing with a gallon of fresh gas & a pint of B-12 carb. cleaner 3-4 times before it looked OK. <br /><br />Ed.
