exnavyman123
- Joined
- Apr 17, 2010
- 123
Re: How can i repair the cut out i did in the side of the stringer?
The motor is a outboard, still on. I assume that area i cut out is part of the stringer system, not sure, there is a "rib" exactly like the one i cut out closer to the side of the boat on each side, which looking at the picture of the back of the boat you can see that "rib" area that goes a little lower than the bottom of the boat where the fish finder is screwed to, this is the only part of this connected "system" that extends all the way to the back of the boat, that may be the actual stringer support?
to screw back in that area i cut out, which is the same exact size as the hole so i assume i have to screw to that cut out piece something that extends larger that the hole to run the screws into the part that is still there , through the piece i'm putting back in correct?
