how can i start engine in a bench?
tayznild
2000 4.3 gi pefs engine. how can i wire it to start it out of the boat?
Don S
Re: how can i start engine in a bench?
Hook the battery cables up as normal. Then make a jumper wire from the battery + terminal to the purple wire on the back of the alternator. That's your ignition switch, unhook to shut off.
Another jumper from battery + terminal to touch on small terminal on starter with yellow red wire to operate starter.
tayznild
what is the shut off? how will the fuel pumps activate? remember my engine is a tbi fuel injector. thanks
Don S
Like i said, the jumper going to your alternator is your ignition switch. To shut it off, remove the jumper.
Trust me, it will work.
bransjeep
It worked for me!
