How can I stop it from leaking in my cabin?
Hi All and thank you.
I have a 24' walk around and the Bifold Cabin Entry Door is leaking. The top bifold door leaks right in the middle of both pieces by the hinge. How can I fix this?
jigngrub
Re: How can I stop it from leaking in my cabin?
Post pics of your door for the best help.
Typically, bifold doors aren't designed to be weatherproof and you may want to consider installing a different door.
If this is a problem when your boat is in storage you may want to consider keeping your boat covered to prevent water from entering this area.
redneck joe
if the 'top' bifold door is a lid or a cap over the bottom bifold door like mine I removed the hinge and added a strip of vinyl before reinstalling. Should work on a vertical door as well.
Mine has two hinges:
