Re: How can I tell if a DP-SM will fit where my SX-M once was?
Thanks. I will invest in the right seal rings and orings. Now for the tough question, and Saintlee, you hit on it. How to select the proper props for this set up? I am at 5290 ft in altitude, and so are most of the lakes I run on. Is there a matrix that will help to dial in the proper prop pitch based on engine hp, drive ratio, and altitude?
Sorry - is this what is meant by hijacking a thread?
