how change water pump Suzuki 115 (2001 model 4 stroke)
JRJ
Re: how change water pump Suzuki 115 (2001 model 4 stroke)
Welcome to iboats. If you don't have a factory Service Manual for your engine, you should get one. The manual will give step by step instructions for not only changing your water pump, but care and repair of all your engines systems. Good luck.
capt g
Yes a manual...but briefly...are there four bolts and a linkage to disconnect..followed by lifting plate and gasket and old impellor off..or is there more to it. Thank you
JUSTINTIME
drop the lower unit
6 bolts plus the trim tab bolt
u need to remove the speed tubing
4 bolts for water-pump housing
look here brownspoint.com
capt g
JUSTINTIME said:
drop the lower unit
capt g
JUSTINTIME said:
drop the lower unit
capt g
What is speed tubing and what does it look like after dropping lower unit.? Does it pull out as I drop lower unit and slip back in when replacing lower unit?
What parts do I replace...metal plate, gasket and impellor? Do I use gasket cement when replacing?
Thank you for your assistance.
JRJ
JUSTINTIME said:
i e-mailed u
Really simple. Did you give him step by step instructions? Just curious.
JRJ
Good job JUST8)
PATHFINDER1900
Justintime,
Would you mind sending me those instructions? I'm catching heck finding a manual for the 2001 df115. Thanks in advance!
grid
As pointed out, it's a simple, straightforward job. If you have concerns, I'd suggest asking a Suzuki tech if you can watch him so you can do it the next time. I'd also not mention beating him out of his livlihood!
ASCTLC
capt g or JUSTINTIME, would you mind emailing me those instructions? I may be in need to replace mine before I get the factory sevice manual.
Thanks a million!
Andy
asctlc@earthlink.net (don't concern yourself with the spamblocker reply, I'll go retrieve the message)
MichaelP
Would have been nice to have those instructions posted here.
stylesabu
Master Chief Petty Officer
you re-opened a post that is 6years old?
