Re: how connect dual battery with switch
Best to get a "make before break" type switch. It can be switched with engine running. The common Perko Switch is this kind.
A switch that breaks connection before making the other one can fry your electrics and electronics if switched underway.
How when your engine is turning the alternator is producing current that goes to the system and battery if you add batt 2 before removing batt1 the current has somewhere to go. If you take batt 1 out of the loop without first connecting batt 2 the current will back feed and blow out your system.
