How difficult to rebuild pre-alpha drive?
TBarCYa
I've got a Mercruiser 888 that tore up the upper gears and is in need of a rebuild. My question is, how hard is it to do? I've rebuilt truck axles (including gear setup) automatic transmissions, transfer cases and have even rebuilt engines so I've got some skills but is there something outside of these skills that would be required? I'm sure that there are special tools required but how confident should I be from a skills perspective that I can do this?
Don S
Re: How difficult to rebuild pre-alpha drive?
If you tore up the gears in the upper, the gears and bearings in the lower are also damaged. There are a LOT of special tool requied for setting gear heights and such, and they cost a lot of money. Plus the cost of the gears and bearings, you would be better off just getting a new SEI drive with a warranty. It would be cheaper than the tools and parts to fix your old one.
Ayuh,..........
For about $1500.00,...........
You could Buy the Tools to repair Your Drive,.......
Or,......
Buy an SEI Drive, Brand New.........
ziggy
sounds like you've got more skills than enough to me. but........
Ayuh,..........
man, ya just gotta say that that's speaks pretty highly of sei...........to me anyways......
unless ya want to add sterndrive rebuilds to yer list of skills.....:)
TBarCYa
Sounds like a new drive for me.... Thanks.
