Re: How do i change the steering wheel?
Automotive steering wheels are going away as all cars now have airbags. However you should be able to find a GT (Grant) replacement wheel. All the wheels are the same but (car wise) you have to buy the adapter hub for the auto application.
For a boat, you will have a time trying to find the right hub application, unless you can contact the steering wheel company and find one directly through them.
Replacement wheels for boats can be found easily enough, they start around 29 bucks and fit right to the existing hub on your boat.
Your wheel should have a key to locate the wheel. That said, the tension created by the nut pushing the taper together isnt as important so dont crank the replacement wheel down, the key will keep the wheel indexed. That way you wont have issues with removing the new wheel in the future.
