How Do I Check Crankcase Pressure In 15HP Johnson ... also, F_R mentioned
bobgritz
I am replacing head gasket on my 15 horse Johnson but in a recent post, F_R mentioned 'crankcase pressure' and I have always been curious of the procedure to check this (and what is the acceptable range). I was tempted to replace the exhaust gasket too and wondered what the procedure is and how does one gauge if, in fact, it needs to be replaced?
HighTrim
Re: How Do I Check Crankcase Pressure In 15HP Johnson ... also, F_R mentioned
If you are getting water in your cylinders or on your plugs it may be from a faulty exhaust gasket.
F_R
Honorary Supreme Mariner
Crankcase pressure is only about 4-5psi, running. Only practical way to check it is to turn it over with the plugs out and listen for the "plop-plop" sound as the ports open.
boobie
Is "plop-plop" a new troubling shooting term ?? Just curious.
