HOW DO I disconnect steering cable??
Wishiniwuzfishin
1974 Johnson 115hp...I am moving this motor from one boat to another. Steering disconnect looks pretty straightforward but since I've never done it before I just wanted to hear from an expert. Looks like I just disconnect steering rod "A" nut and remove arm.....and loosen/remove nut "B" and cable will pull through right? Thanks in advance to any replies.
Al-53
Re: HOW DO I disconnect steering cable??
yes thats correct way..I do the same to mine to clean the tube and make sure its greased...
Al
Wishiniwuzfishin
Thanks Al-53. Just wanted to make sure I didn't screw anything up. Came off pretty easy.
