Hello all,
I just bought a compression gauge and want to do a compression test on my 1981 Evinrude 150V6. I just want to make sure I do it right. I have heard that I can damage the ignition system if I do it the wrong way. Should I disconnect the kill switch before taking the spark plugs out and doing the test? Also, what is it when people talk about grounding the wires to the block while performing the test, is this necessary???
Thank you!!! I don't want to screw anything up!!!
