Hi,
I purchased a 1989 Larson used boat (3.0 engine) which is powered by a Mercruiser Alpha One Lower Unit.
Lower Unit Serial Number 0C787706 (I believe this is a Alpha One Generation 1 unit)
We have had a small lower unit leak from the weep hole since we purchased it. I took the lower unit to a repair shop who pressure tested the lower unit. He identified the leak as below the water pump. It took him several attempts to seal it...trying a combination of old and new water pumps and gaskets. He finally told me it was fixed, and held pressure. I paid him $100 for this repair.
About a month later, I was prepping the boat for a launch, and ran it on muffs in the driveway. Lower unit oil was "oozing" out of the weep hole. I never did get the boat in the water this year...as I was afraid of doing some damage.
Time is now permitting me to winterize the boat...and hopefully, take care of this issue once and for all. I have received a Sierra Seal Kit 18-2652. I did pressure test myself today. It appears the base of the water pump is leaking again.
Attached are a few pics showing the lower unit, water pump, etc.
Question...why would the water pump not seal? What can I do differently from what the repair shop did?
Thanks for any advice!
