How do I fix this disconnected spark plug?
wvyen
Hello,
So i had a loss of power issue last weekend. When I opened my cowl to see if I could see an obvious problem I noticed that one of the spark plug wires was disconnected. My question to you all is how do I reconnect this? Do I need to replace the whole box that is bolted to the block or do I just jam it back in there?
Photo #1 is the plug wire
Photo #2 is where the wire is supposed to be connected.
GA_Boater
Re: How do I fix this disconnected spark plug?
That's not disconnected, that's busted. What motor including serial number?
wvyen
So I did a little leg work (I know I should have done in advance) It appears that I will need to purchase a CDM Module 827509-A1 that should run between $75-$100. If I'm wrong please let me know, otherwise thanks for looking
Timestep
A skilled amateur engineer could get it going with some new wire, a needle and some good adhesive.................
