Re: how do i get an inboard ready for the season !!!
I would suggest first and foremost to drain your gas tank and get some fresh fuel in there. I would change the plugs and the oil and filter as well. Might not hurt to spray a little pentrating oil in the cylinders while you have the plug out.<br />Check to see if you have a fuel filter/H20 separator and change that as well. Put a charge on the battery. <br />I used to have a diesel inboard, and after any extended period of inactivity, I would pour some dawn soap on my raw water pump impellor to help it prime and lubricate it until the water came through. You may not be able to do that with an I/O and I now pour a little in the hose before hooking up the muffs to start my outboard on the trailer. <br /><br />Good luck.
