how do I get reverse back?
thriller
I pulled the bottom of the leg off on a 82-83 merc 7.5 and I can not seem to get it back in right. If the shifter is in Neutral it goes forward and if it is in reverse I go to neutral. After this has been messed up what is the best way to get it lined up proper again.
THANKS
emckelvy
Re: how do I get reverse back?
Remove the lower unit. Shift the motor to Neutral.
Cushion a pair of pliers or Vise Grips with tape or suitable shop rag (to avoid marring the shift shaft splines) and rotate the lower unit's shift shaft until the lower unit is shifted to neutral. If you turn the prop a bit as you're shifting the lower unit, it'll be most evident what gear you're in and when you hit Neutral. There's a very limited range of travel in the shift shaft to induce shifting action, so you can't really get too lost. Turn it one way or the other to get to Neutral.
With both lower unit and motor shifted to Neutral, reassemble. You'll need to rotate the flywheel in order to engage driveshaft with crankshaft, as you're reinstalling. Be sure you've pulled both spark plug wires off the spark plugs before doing so.
HTH.........ed
thriller
thanks, I will try again. I actually tried to put the shifter in neutral and the lower leg in neutral as well but I will try it again. Could I try the same thing by putting it in forward in both places? The splines on the shift rod have a few that are machined off and it is hard to see but I imagine they they should only fit in one way. :confused:
