IHDiesel73L
Thread starter- Joined
- Aug 2, 2010
- 70
So this MFG Carefree was full of water when I found it-the plan is to gut it and glass in new stringers, new transom, etc...so how do I get the top off?
I should have gotten closeups, but you can make out the flange where the top meets the hull here-no bolts or screws that I can see, just glass. Does this mean I actually have cut the top off?
On the inside where the top meets the hull there appears to be some kind of spray foam-for flotation I guess? Do I just cut that out too? My next question has to do with the deck. The interior deck is all fiberglass and will deflect a bit when I press hard with my foot, which I'm assuming its not supposed to do, so that would mean that there are structural issues underneath? First, what is under the glass deck? Plywood decking then wood stringers underneath that? Will I have to cut the glass decking out or does that come out when I separate the "top?" (the part that covers the bow and the rails, etc-what is the proper term for that?). My primary goal for this summer is to get the boat apart and remove all of the rotted wood, which I'm sure there's plenty of. I have a dry place to keep it for the winter, so as long as I'm in a position where I can start glassing next spring I'll be happy. I did read that some MFG's were all glass, but I doubt I'm that lucky
If all of you could take pity on my lack of experience here I'd appreciate it. I don't know a lot about boats yet but I'm learning-I'm a pretty hardcore DIYer who has tackled everything from complete home remodeling to engine rebuilds with a pretty high degree of success, so with some good how to information I'm confident that I can do this.
