How do I identify my prop?
chimmike
Previous owner installed a rapture 3 blade stainless prop on my 5.0 1991 celebrity 190, alpha 1 g2. No other identifying markings are visible anywhere on the prop.
I can obviously measure diameter, but what about pitch?
Slip Away
Re: How do I identify my prop?
Rapture propellers are no longer made. You can still find some old stock out there.
The part number was stamped on the side of the hub on earlier models, and on the hub
end on newer models. If your XHS bushing is inserted in the hub, it will cover up the
propeller part # on a newer Rapture. To identify, you will have to have the hub/bushing pressed out.
