How do I install a temp Gauge?
Dale002
I have a 94 sport Jet 90 that has the stock water temp set up. Sensor and horn.
I would like to install a temp gauge on this motor. Has anyone done this?
Silvertip
Re: How do I install a temp Gauge?
You buy the gauge and follow the directions. The gauge you buy needs to be for an outboard and to be useful needs to be calibrated for an outboard. Most that are available today are calibrated C-N-H since most people don't know what normal is anyway so numbers are useless to them. You need a sender that matches the gauge. Teleflex and Faria and others have them. Many gauges are calibrate 120 - 260 degrees. These are for I/Os which run hotter than outboards or jets so the needle would never get off the 120 mark.
Dale002
Thanks a bunch Silvertip. I thought they ran hotter than that.
