aspenshayn
Thread starter- Joined
- May 27, 2011
- 24
So I just glassed in my stringer with 1708 and epoxy resin. I worked it and worked it but still seemed to have air bubbles. I know when I removed my old stringer, the wood was completely rotten and just fell out after i cut top off the glass. The glass was still incredibly strong. So will my glass job be solid? is there a way to check (kick it or something, as you can tell I don't know much about glass)?
I'm hoping because I used epoxy resin, it will be stronger.
Do I need to lay another layer? I've read that if I use epoxy there is no need to lay another layer.
This was not as easy as it I thought it would be, but if it holds, it wasn't bad.
Thanks for the help through my other threads, I would have been completely lost without your help!
